CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Problem: What's this sound? (VIDEO)
Old Sep 14, 2009 | 04:58 PM
benz_addict's Avatar
V12TT
Really loud squeaking sound, happens during cold starts and fades away after normal operating temperature, well most of it.
Listen to the car as it rolls down the driveway (not my car). But I have the same problem.
http://www.youtube.com/watch?v=nMwsGwfk9iY
Old Sep 15, 2009 | 01:28 AM
S-BOPOH's Avatar
'13 ML63 Performance Pack
Have you done any engine upgrades, pulleys, belts etc?
Old Sep 15, 2009 | 09:28 AM
SSIIICK's Avatar
G550 4x4², Phantom, 675LT Spider, Aventador SV Roadster, P1, 812 Superfast, Portofino
Malfunctioning pulley?
Old Sep 15, 2009 | 01:35 PM
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
Sounds like your idler pulley make be about to give. It could be a worn belt as well if you have over 40k miles on the belt, but usually belt isn't that loud. When the idler pulley bearing gives it can make some pretty nasty noises. Buy a can of serpentine belt conditioner and lightly spray it on the belt as its running at idle (on both sides) don't coat too much. See if the noise goes away, if it does that means its the belt, If not then its most likely idler pulley.
Old Sep 15, 2009 | 03:12 PM
V12TT
My car is pure stock. Both belts seem to be very tight and have aggressive teeth marks still left. I will try the belt dressing and report back when possible. Thanks for the answers.
Open for more possible solutions and answers of course.
Old Sep 15, 2009 | 05:14 PM
AMG
How many miles are on the car (most likely still original belt)?
Old Sep 15, 2009 | 07:03 PM
V12TT
It's got 100k miles...
Old Sep 15, 2009 | 07:11 PM
AMG
ya replace the belt. You can use belt conditioner and it may get you another 5-10k miles if you are lucky, but eventually it will fail. Its cheap, belt is like $35-45 with an hour of labor roughly. Not a big deal.
