2003 CL55 start up issue
Solution - called Mercedes and the roadside service tech came and replaced the battery under warranty. All problems were solved with the battery replacement.
Hope that helps.
JDB
when? elaborate replaced...you might have a large drain in the system if the battery just replace..maybe within 5 days?
or battery itself is bad...
like the 2nd post say...recheck everything..you could miss..
find someone with a battery tester/ volt meter..and do a battery test, current draw test..and charging test..
good luck
