Cl55 amg custom 3" back exhaust with x pipe to amg mufflers and custom 3"intake
If the stock mufflers have a 2.75" inlet then going to 3.0" before that is a complete waste. As I stated before when you modify the system you must take into account the entire system, merely trying to do one thing here and something else there haphazardly ... the results won't be good
It's when you do them yourself it's the problem, too much or too little cases harm to your MAF and/or engine.
So basically you need to fit a new set of K&N everytime!!
Antway, good luck, Colin.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
