CL 55 - undercarraige plastic covers
I've caused some damage to the underside of my car from a shredded tire on the highway.
Does anyone know where I can find the front most plastic cover, and the one immediately behind it which has the two snorkels to help cool the bottom of the motor? MB was 460 for parts only.
If aftermarket is available would you guys recommend it?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Agreed, that's a salvage part that probably could come in useful.
Can it not be repaired? However, you may just have to get it, your talking about a lot of suction underneath the car at speeds, may not be worth the risks involved.
