CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL55 Primary cat delete (VIDEO)
Old Nov 15, 2009 | 02:17 PM
benz_addict's Avatar
V12TT
Thumbs up CL55 Primary cat delete (VIDEO)
The right side cat blew under spirited driving so I got both cats replaced with straight pipes.
Resonator and secondary cats are still in. Here's how it sounds now:
VIDEO: (Don't forget to choose HQ)
http://www.youtube.com/watch?v=Go803OiiOT8
Old Nov 19, 2009 | 10:20 AM
Il Capo's Avatar
hey i know this post is about a year old, and theres always those select few who give you **** about bring stuff up from the dead (lets not forget about the "search" cult too) but I wanted to know if you got a check engine light after deleting the primary cats?
Does anyone no of a o2 simulator or trick that will allow our cars to run with no primary cats and without a check engine light, my cats are rattling too unfortunately.
Old Nov 21, 2009 | 01:08 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
did you notice any change in power/torque
Old Nov 21, 2009 | 06:09 PM
V12TT
Capo... you have to delete the rear O2 software coding from the ECU if you want to bypass the O2 CEL. I got this done from a respectable local ECU tuning shop. If you don't do this then you will definitely get a CEL.
shardul... I got an ECU tune at the same time my car was in for the O2 delete, so I really didn't get a chance to notice. All I know it sounds so much better in person.
Deleting my resonators soon!
Old Dec 14, 2009 | 02:22 AM
beaskho's Avatar
yamaha
I accept with information:this post is about a year old, and theres always those select few who give you about bring stuff up from the dead lets not forget about the "search" cult too.
Old Dec 14, 2009 | 09:11 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
You have any video or pics of the work completed?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
