CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
aftermarket heat exchanger for cl65?
Old Feb 3, 2010 | 05:47 PM
02cl55amg's Avatar
CL65
thinkjing about installing an aftermarket heat exchanger in addition to my trunk resovoir. has anyone done this? is it worth it? eurocharged is coming to vegas to tune my car, so i'd like to be modded up
Old Feb 4, 2010 | 09:55 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Eurocharged has a front mounted H/E for our cars..
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Feb 5, 2010 | 04:38 AM
02cl55amg's Avatar
CL65
i know. i was just wondering if anyone has done this mod in addition to other cooling mods such as the trunk resovoir. is it needed after you do the resovoir? i figured the more cooling mods the better right?
Old Feb 5, 2010 | 09:48 AM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
I would agree with that statement...it certainly shouldn't hurt. I would just make sure you have enough pump pressure to move the extra coolant especially since it is travelling over a greater distance with the trunk reservoir.
Tom
