CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
ABC Valve Block Removal
Old Mar 2, 2010 | 07:31 PM
2003 S600's Avatar
2003 s600
For those that have tackled the ABC valve block, how did you loosen the line connections on the valve block? I tried but they are way too tight. Using an open end 17mm wrench and tapping it with a hammer only got 1 out of 5 loose. Any Ideas?
Old Mar 3, 2010 | 09:29 AM
Nightflyer's Avatar
03 CL55
If you need any parts I have valve blocks and ABC pump from a CL600.
In terms of doing the job by yourself it is very tough if you don't have the proper tools and assitant.
Old Mar 3, 2010 | 04:46 PM
2003 S600's Avatar
2003 s600
Thanks, I have 2 new valve blocks. Just need advice on how to get it removed.
