CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
ic trunk resovoir installed-i have some questions...
Old Mar 13, 2010 | 05:36 AM
02cl55amg's Avatar
CL65
installed the trunk res last night night what a pain. i have a few questions for those that have done this mod. first, do you guys run both pumps- the cm30 upfront by the HE and also the cm30 coming off the tank? i was told just to run the 1 cm30 in the trunk. second, the line coming off the pump bringing cold water from the tank-is this routed up straight to the intercoolers or to the lines next to the heat exchanger? mine is connected to the hoses by the HE. third, where to you get the ignition lead in the trunk for the pump? any other tips i should know/do? tried also to add an additional heat exchanger up front, but to find out that what i was told was a 2nd heat exchanger currenty in place behind the bottem bumper is actually an oil cooler. euocharged will be here tommorow to dyno tune the 65 and try to best my 590rwhp
