CL55 Supercharger/Intercooler Questions
My CL55 runs like a bat out of hell but I don't have anything else to compare it to so I can't tell if everything is actually working as it should.
The Kompressor clutch doesn't have the tell-tale 'chirp' so I am hard pressed to tell if it actually engages at 2700 RPM. Short of putting a light in the clutch circuit to see if it comes on while driving, how can you really tell?
Same thing with the intercooler pump-
I'd like to be able to connect the pump circuit to +12 to see if the pump runs when the car is off. There is no other way to tell when it's running because there is so much other stuff going on under the hood, you can't hear it.
Any advice or suggestions would be much appreciated.
Thanks!
Elm
