Opinions welcome about a 2003 CL 55 that I looked at today.
In short - run away from the car.
These are the least of your concerns about the car. You will want to find out if the ABC (Anti Body Control) the Hydraulic suspension on the car is good or if it is going bad on that car. To replace these are very expensive and you will not like it, if you plan to stay on a budget. Cost on replacing per strut more or less $1300-$1600. I manage to find a Mercedes tech that does work on the side and can get parts from the dealer that quoted me $700 installed per strut. That is the cheapest I have found.
I have an 03 myself and since having the car I have replaced the intercooler pump which is common to go bad,... that is not as expensive. Cost to replace $90 for the pump and $50-$60 labor. I would suggest replacing this either way to help with the performance of the car.
Next I heard some rattling sound in the engine, and it turned out that the super charger pulley bearings was coming out. (Had that replaced asap)You don't want the super charger to break on you.... $$$$ for you wallet.
When looking into buying these type of cars. Make sure to do plenty of homework on the car and the car that your are planning to look at.
Make sure to prepare some maintenance funds just in case you will need to fix things.
Cosmetics you can always work on anytime, make sure the car is running well first before you want to make it look good.
my 90k mile cl65 has all the original struts and abc parts....they work perfect....i keep my abc in sport mode all the time too
the more miles u put on the better the car will be....my 90k mile cl65
