Took the CL55 to the track.....
Dyno numbers were 381 rwhp and 448 ft lbs tq. Lowever then I expected along with the 1/4 times. I will say our local track is not the greatest (Portland International Raceway)
Here is a link to it. http://compare.ebay.com/like/2608062...=sbar&_lwgsi=y
2nd. Link.
http://www.mymbonline.com/forum/272-...mps-stock.html
Reason why, your car will have good runs and then it will pretty much go in to limp mode to disengage the supercharger so you don't blow up your motor. The stock Bosch pump can't handle it. (I don't know why they MBZ used this pump) I was running in the high deserts here in SoCal and I would smash on the car a couple of times and then, nothing just the way you described what happen to your car. Once I change my pump, no issues at all. I even smash it with the air condition on and not problems what so ever.
Good luck.
