03 Cl55 AC wont turn on
2003 CL55 AMG
Light on the "AC Off" button just stays on, and wont blow out any cold air. any ideas on how to fix? im hoping its a fuse or just needs to be recharged??
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
I had this same problem early on and it was fixed under warranty. In my case it was the EVAP temp sensor that went bad. Part # 2208300772.
When the A/C off button is illuminated and won't turn off it means your AAC module is sensing either a temp sensor malfunction but 90% of the time its due to the refrigerant sensors to low of a charge meaning a leak somewhere. Even if you charge for A/C back to specs it needs to be reset with a scan tool in the AAC module before you can switch it back on!! Hope this helps
2003 CL55 AMG
'03 CL55 ///AMG
I had similar issues with the AC. It can be a variety of things. First off, a code has been thrown to shut down the AC. This is primarily because when the codes get thrown, the computer usually reads this as a loss of refrigerant pressure. The compressor uses the refrigerant to lubricate itself and if it were to run without refrigerant or a low pressure of refrigerant it would harm the compressor. First time that this happened my dealership (Atlanta Classic Cars) recharged the system. They added a tracer chemical to the refrigerant to see if there was a leak. There was none. The second time (about a week later) they found a leak when running the trace. Parts and labor about 1200. The third time, I now take my Benz to Blue Ridge Mercedes in Atlanta, it was only because codes were thrown and the computer needed a reset (I had run the system for a while with the doors open prior to this). So the net of this is, it could be a lot of things within the A/C system that have caused this.
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
In the W220 section, try it, it works.
Get your system re-gassed, you should be good.
