CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
2003 CL55 can not change digital clock
Old Nov 29, 2011 | 10:52 PM
rsjr81's Avatar
cl55
I have a 2003 CL55, it had some work done where the battery was disconnected for quite some time and after I noticed a problem with the digital clock in the display next to where the current gear being used. It keeps time but it is off by about 1hr 10min I have since went into COMMAND and set that clock which was already correct but the other clock wont sync. I also do not see an option to change it through steering wheel, it is not in convince settings.
Do I have to have a dealer fix this problem?
Any ideas?
Thanks.
Old Nov 30, 2011 | 02:17 AM
Ezah's Avatar
'05 CL65
Does your navigation work? I think it needs to sync via the Nav system or so on. Mine wont Sync as I dont have a working disc for it so it always shows japanese time (its an import). You could disconnect the battery at midnight or w/e.. but that shouldnt be necessary.
Old Nov 30, 2011 | 11:21 AM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
If your nav doesn't work then you won't be able to set the time. I had the same problem.
R.K.
Old Nov 30, 2011 | 02:12 PM
rsjr81's Avatar
cl55
Yes my NAV works and I have discs, at least the last time I checked. So do you think that I need to pop in a NAV disc and go to that part of the interface to have it sync, is there a button or something or should it just happen automatically.
The main thing that sucks is that there is a cd stuck in the disk drive so I will have to get that out first, I have another thread in hopes that someone has the answer to that.
Thanks.
Old Nov 30, 2011 | 02:41 PM
rsjr81's Avatar
cl55
Just put nav disk in and brought up interface, however the clock did not update automatically.
Old Nov 30, 2011 | 02:45 PM
awiner's Avatar
2003 CL55 AMG
Push your SVC button on COMAND. There is a county/time setting option there that will update the digital clock.
