Considering CL55 purchase
2003 cl55 amg, 2008 Range Rover Sport SC
To be honest id ruunnnnnnnn!!!! Benz in general are very picky cars electric wise. I once purchased a salvaged m3 rust had already started in the rear subframe. Long story short rear subframe broke of car!!! Not mentioning the shorts the car had after all electrical being switched.. If you get it good luck!
MB; 55KCL AMG, SL550 SLS AMG G500 Cabrio 280SL ML350 CLS550 ML500 E55 AMG CL500 S600 SLK32 AMG
If you haven't replaced your hoses and accumulator, I would do so as preventative maintenance. That's right when I started to dump big money into ABC repairs. I'd have a good indy remove all the rubber ABC lines, take to a hydraulic hose shop, and replace them with a higher quality hose.
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
Has anyone been able to replace the ABC Hydraulic lines with better quality ones so far ? I know the subject was raised and suggested , I dont recall reading that in fact it was done .
#32
E55, GLS450, GL63, GLE350
Do a Yahoo or Google search for hydraulic hose repair in your area. Any hydraulic hose shop can repair your hoses and upgrade them to a higher quality line at a fraction of the new MB hose/s cost.
#35
Sure, the warranty will fix the ABC if it is covered but the long term effects of the tiny metal shards in the lines, blocks, and stuts will lead to more and more problems over the long haul.
