805whp V12 from SPEEDRIVEN
Marcin, incredible results man!! I talked to ya last week and thanks for the help, one of my turbo's is failing now thats where a few psi's of my boost has gone....Anyway's im gonna be pulling the Motor and trans out this weekend and get the trans sent up for you to build, anyways PM me and let me know if I can get a turbo set up for my car and some details.....I know its not 100% complete but ill gladly be another test mule and see how everything holds up!!
CL65
Tell him I said Hi and that he should get into tuning MB's, it's a piece of cake
Haven't been down the track yet as tracks are closed out here until April. I think it will run really really strong. It will run a 9 second pass this year. Bet on that.
#37
CL65
#38
Wow-that sucker must pull like a freight train up top!
I hope your going to the track today, I want to see a min of 140mph.
New plugs, boots, coil and map sensor in mine. She's pullin hard and will set off the traction light at 80. Too bad are track is closed in "good" weather
#39
2013 Audi S4 Stasis, 2013 Audi TTS, 1996 C3500 Dually, 1967 442, 2005 CL65-Sold, 2006 E320 CDI-Sold
C'Mon Marko.....GreatLakes is open
I'm taking my car over to Marchin tomorrow evening for some work (IC pump is shot). Let me know if you're around.
#40
It seems you guys have the tuning of the V12 cars down. Why is it that people are melting the V8 pistons at much lower horsepower levels? I can tune AEM EMS, Ecu Flash, and Ecm Link for Diamond Stars, but I'm really at a loss at why these motors are failing at relativity low power levels. (600 whp) I have not done too much research but it sounds like number 8 is leaning out and melting the piston. Is this a known mechanical issue?
#43
I talked with SpeedDriven today and they explained to my why people are selling failing tunes. If I ever change my mind about modifying this car they will be the company I use. They were also nice enough to share some technical information not all tuning companies give out. Thanks guys.
