CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
ABC cooling fan & intercooler/mini radiator report
Rating: Thread Rating: 4 votes, 5.00 average.
Old Feb 22, 2012 | 12:25 AM
driveability's Avatar
Cl65 AMG
I just had to install this fan. I may not need it but it fit perfect ! I'm working on a thermostat.
I posted earlier about re-pluming the mini radiator into the intercooler circuit and adding a Meziere Remote Electric Water Pump WP136S I got it going a week or so ago. It seems to work well, after running the car getting on the throttle a bit, pop he hood to find the coolers cold ! Really cold and conversely the two air cleaner housing really hot.
ABC fan Picture
I also decided to attempt to give the Ign/injector module a bit of a lift. I added 4 rubber insulators to help it because it seems to get hot under there. I have no idea if this will prevent failures but it sure can't hurt. I added a second ground to make sure the circuits happy.
Module Picture
The fan is a 5 1/2 inch unit made for ATV's. It pushes about 300 cfm.
Old Feb 22, 2012 | 09:12 AM
alx's Avatar
alx
nice...
but i am not aware of any overheating problems with the pentosin.
so... you _might_ have provided a solution to a non-existent problem.
lifting and insulating the engine ecu on the other hand seems like a good idea.
Old Feb 22, 2012 | 04:44 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Nice creative work.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Feb 22, 2012 | 05:44 PM
benz_addict's Avatar
V12TT
Nice work! Raising the module seems like a good idea, preventative failures (causes misfires on one bank).
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
