I BOUGHT A CLS AND I DO HAVE A FEW QUETIONS
I do have a few quetions about problems i have.
1----This happens when the car is warm about 85 degrees
When you hit the gas on neutral the rpm goes up to 3000 rpm but when it should drop it stays at 2000 rpm. Sometimes its drops to 900 or 1000 rpm ?? sometimes not. i have read the fault codes with at bosch KTS 650 and it says fault code 43.
Can not adjust the slowly.
Even when you drive the car and let the gas goo and you hit it again, its feels like the car go on the clucth very hard. i suppose it have with the throttle too ?
It should be the throttle ? the throttle is replaced since before with a replacment ithem ? But ethier the replacment have the wrong item number. The item number is a275 141 00 86. It should be a a113 141 0625 as Mercedes Says. Some suggestions ?
2--- As i know Mercedes did have problems with the valeo radiator.
it was mixing cooling liquid and transmission oil. Is that still a problem on a 2006 ??? Otherwise i have to change it before it got broke.
3--- SBC Brake system. Sometimes when i want to reverse i feel that brakepedal is vibrating ? Does it have maybe with bad battery for the sbc system or maybe something else ??
4--- How do i change brake pads and rotors ?
- dont unlock the car ? and change only ?
- Disconnect the sbc wire cable ?
-Deactivate the sbc trought the Bosch ?
The car have stayed still for 1,5 year.
I hope someone could give a little advice on this Problems. Relly thansful for any advice.
