What intake air temps are you seeing?
I thought it would be a good idea to compare set ups and intake air temperatures. My mods are speedriven ecu/tcu and johnson cm30 ic pump everything else is stock. Last night it was 62 degrees ambient and while crusing 70-75 mph I would see anywhere from 84-95 intake air temps while most of the time it would stay around the 91 area. When I came to a stop iat would be from 115-130 depending on how long I was stopped but as soon as I moved the iat's would start dropping instantly. It sure gets hot fast while stopped I would hate to see what the iat's would be if I was stopped in 100 degree weather. I would guess that it would be completely heat soaked. I heard that heat soak is 159 degrees? I didn't get a chance to log them during a pull because I get coil pack misfires at wot.
