CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
How to remove MAP sensor?
Old 12-23-2012 | 04:50 PM
Barrett77's Avatar
2003 cl55 AMG
map sensor
Hi sir
yes
i agree with your reply!
However i must find the cause of the the engine shudder at idle
I believe it an injector bank 7 or 8
Tomorrow to clean the pre cat o2 sensors
maybe it will cure my problem.
My EGA valves are nice and clean
However it will be wise to do a compression test.
im a little scared if its a bent valve.
Old 12-23-2012 | 05:58 PM
biker349's Avatar
cl600
man, you are spinning your wheels big time!!! you've spent so much time, money and worry trying to trouble shoot this problem all in the wrong way. get the freaking car on a star computer and find out what the problem actually is. you are going to wind up breaking something that didn't need to be touched. penny wise and dollar foolish! get the codes read and check out the trans. mount.
Old 12-24-2012 | 02:12 PM
Barrett77's Avatar
2003 cl55 AMG
Smile Map sensor
Hi sir !
I had a few codes thrown at me
P0412
P2024
Air pump valve
I do have my ABC light in blue
As I have recently changed the suspension
Oil.
I think it needs the ride height setting.
Have added a triple action injector cleaner
I think it's helped to over come the engine
Shudder, but I can't be sure yet !
It's £15 a bottle in the UK, I will continue
To use it until I have a result.
Can injectors be cleaned at home?
Many thanks sir !
Old 12-24-2012 | 02:28 PM
biker349's Avatar
cl600
did you bled the abc system when you added fluid? me thinks you need professional mechanical advice. find a good mechanic.
Old 12-24-2012 | 06:22 PM
Barrett77's Avatar
2003 cl55 AMG
Smile Map sensor
Hi sir
Thanks for replying to me.
Yes had a rodeo test done with new
Fluid at MB London
The wishbone rods at the time were seized
Therefore the ride could not be set
Now I fitted all four new ones
No leak in the system
Car looks fine as it is surprisingly !
I have a clear 3 gap finger rear
A clear gap 2.5 front
I will look into this at a later date.
It's the engine sudder I'm concerned about
Could it be the fuel pressure regulator ?
Car misfires slightly
All engine and tranny mounts are new
Done last few weeks
Its a mechanical fault
No codes are shown
I'm scared it might be a bent valve !
Hope your ok this Xmas sir !
Quick Reply: How to remove MAP sensor?
