Cl55 sc pulley kit
2003 cl55 amg, 2008 Range Rover Sport SC
Cl55 sc pulley kit
Anyone selling a sc pulley?? Looking to purchase anyone know her I can get a killer deal on the kit??
1 Post
03' CL55 AMG
Do you need the whole clutch assembly? Usually you just need a bearing pack, the OEM pack will cost you around $80 on eBay and you can take it to a performance shop which will install it for around $300
Had mine replaced last year when my bearing pack blew
If you need the whole Clutch assembly it will be hard to come by and will cost around $1,100-$1,300 and around $300-$400 labor at an indy
Either way you can just disconnect your SC belt until you get it fixed so you can still drive the car
I think you got confused. 180m pulley is Crank pulley not the SC pulley.
Usually smaller SC pulley will increase more boost and crank pulley has to go bigger size as 168, 172, 175, 178, 180, 185, 190, 195, 200. I don't think anybody went bigger than 200. Now, the bigger you go the more heat will generate so if you want to go bigger pulley, you might consider upgrade your Cooling system such as IC Pump, Heat exchanger.......
You can visit in E55 W211 or Planet supercar under 55K section. Few people can help from Eurocharge, SpeedDriven...... and you have to do ECU tune if go with bigger pulley. Good luck.
https://mbworld.org/forums/w211-amg/...k-hp-kits.html
