Any of you 65ers consider 18s in the rear?
R.K.
but i am guessing if you do put 18 inch wheels on the rear you are going to compensate with a thicker ( higher profile ) tire so at this point i guess there wouldnt be any problems...
on my cl65 i know if i wanted to i can installed tires that are thicker ( higher profile ) with out any issues. so my question is why cant you just install a thicker profile tire on your stock 19 inch wheels insted of the factory 275-40-19 try 275-45-19 gives you 5% thicker tire or 275-50-19 gives you 10% thicker tire... might look funny but better then trying to go to a 18 inch wheel... hopfully that extra 5-10% increase will resolve your tire problems
tire warranty is a great idea..
You can also increase the fronts as well, but just overall making the size bigger will cause problems like the suspension bottoming out more easily and changing the gear ratio of your car. Also your speedometer will be off. That's why I think going to 18 would be a better idea...
EDIT: Here's a reference for stock tire size: http://www.tirerack.com/tires/Select...5&autoModClar=
