Tuning software
Tuning software
Does anyone offer tuning software so that you are able to tune your own vehicle? Or has anyone tried the AEM or Megasquirt systems as a piggyback and had success?
R.K.
Can you elaborate on how the driveability is lost? Those systems should control the engine portion. You will maintain the stock ecu for purpose of trans controls and all the other odds and ends.
I already have a highly modified car running an AEM stand alone. No matter how good the tuner is, it will never be the same as the OEM ecu tune from the factory. The OEM company spent millions of dollars perfecting all of the maps so if all of a sudden you drive to the mountains or down to sea level, the car retains its stock oem feel. There will always be some hickups and minor quirks with aftermarket stand alone ecu's.
R.K.
R.K.
R.K.
R.K.
PLATINUM SPONSOR
Good software and support can be around 15K. Easier to let Eurocharged tune your car and buy one of their package specials.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
I too would like to be able to tune my own car and understand both sides. There are likely a few engines that made tons of hp but lost pistons in the process. Being a MB V12 or V8 lends itself to a different market demographic. There are just two few customers to open up the market. I had a spare engine for a while and was going to run it using a stand alone system but someone made me a good offer and off it went to a new home. I am used to cracking open my cars, however this 65 may never run again once its opened ! For now in my opinion let the experts (guys with the software) do there thing. HST, wouldn't it be nice to have control
