Funky smell in the cockpit from the Engine
Mercedes CL55
I noticed that every time I slam on the pedal and take off, there's this strange smell that comes into the cockpit from the engine. Does anybody know what it is or have the same problem? If so please let me know what it might be, just curious. Again, this only happens when I floor it.
Mercedes CL55
is this normal, or are the cats bad?
The a/f on the force fed Mercedeses is always rich to be on the safe side. This combined with slightly dirty injectors might result in unburnt fuel ending up in the cats and the resulting smell.
A chevron Techron fuel treatment and some spirited driving might clear the issue for some time.
1 Post
w215 cl65, W212 E63, R53 Mini Cooper JCW, E92 328I
ya my car smells like that also.. it is the connection from the turbo to the downpipes. there is a v-band clamp and that leaks a bit.. and it smells really bad when i enter the freeway a bit fast... so once i got my catless downpipes it doesnt smell anymore becuase we used better vband clamps
What we talk here is the after cat rotten egg smell when unspent fuel ignites in the cats.
Dirty air filters is also very common on n/a motors to cause rich condition.
If you have das the car can be leaned out a bit in about 5 minutes on the force fed r230s. Again- not sure on your car though.
1 Post
Your smell is pre- cat and is because the steering shaft rubber boot in the firewall might be failing. This allows exhaust from the turbos to enter cockpit. Is your steering squeak also when turning the steering wheel? That sometimes is a tell tale of the boot failing.
i will look in to that, i do recall hearing a noise but it was from my brake pedal
