Air intakes help much?
It's debatable as to if it'll suck in hot air but it lets cool air in to the whole engine compartment now from the front.. I'm thinking that is a good thing versus less cool air circulating..
Pretty happy with the response time, but I might put the intakes hoses back on to see if there is any difference. I'm also thinking of dremeling two of the air redirect blades that sticks infront of the intakes that redirects the air flow towards the radiator section..so more air flows into the intakes hoses.
I'm sticking with the stock paper filter, it's fine..
I'm still thinking of getting Speedriven intercooler / Scorpion kit.. or mod something similar. I love that carbon fiber cover.. hate to lose it.
Wonder if I can get bigger intercoolers, remove the airbox and still keep the carbon fiber cover..
. The IC's would basically just help keep it cooler longer so that the car runs more consistently so I doubt they would offer any significant power by themselves. So most of the power would have to come from the intakes and tune. Right now with the tune only I should be around 660hp therefore if the kit brings it to 750 it equates to 90hp more for $5k. hmmmmm.....
. The IC's would basically just help keep it cooler longer so that the car runs more consistently so I doubt they would offer any significant power by themselves. So most of the power would have to come from the intakes and tune. Right now with the tune only I should be around 660hp therefore if the kit brings it to 750 it equates to 90hp more for $5k. hmmmmm.....If you don't get larger / better IC's it will not hold the HP, car will get to hot to fast and the numbers will drop off just as fast.
Best to add better HE at the same time.
What mods and set up did you do to run your times and what gas did you use?
But a bigger HE does sound nice. How much bigger is it than our 65 HE and do you have any pics?
I ran a few gallons of 100 octane. If you take the time to run the lines to the trunk, you may want to consider new lines up top over and around the strut towers as opposed to leaving the stock metal lines that cross over the heads in place for heat transfer. There is a post about it from jaycl600.
One other thing I'd like to ad which is my own personal preference. For me I would rather have the trunk tank than convert my washer reservoir to one. For one our cars are nose heavy so if I had to put weight in the car its best to put it in the rear. Also the trunk tanks are 5 gallons which is way more than the washer would hold so fluid capacity would be greatly increased. The trunk tanks have the pump mounted to them so its now easy to change if/when the pump dies. With the washer you'd have to plumb it where the pump sucks from the reservoir not pushes through it.
The trunk tanks are nothing new we use these all the time in drag racing for forced induction cars. They are proven systems. Chiseled performance is a very popular company and they can custom make anything you want.
