CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
'12 CL63 Car & Driver Test
Old Jun 14, 2012 | 09:29 AM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
http://www.caranddriver.com/reviews/...mg-test-review
Pretty strong acceleration #'s once rolling.
0-60mph: 4.0s
0-100mph: 8.8s
0-130mph: 14.2s
1/4m: 12.3 @121mph
Not bad braking and handling figures either for a 4,825lbs car:
70-0: 167'
300' skidpad: .90 g
I don't think I have seen a U.S. magazine test a W216 CL65. I would be curious to see how the CL63 PP stacks up against the V12 Biturbo.
Tom
Old Jun 14, 2012 | 10:57 AM
Vic55's Avatar
Administrator
0-60mph: 4.0s
0-100mph: 8.8s
0-130mph: 14.2s
1/4m: 12.3 @121mph
70-0: 167'
300' skidpad: .90 g
Tom
Nice Tom- I have always noticed that C and D has some crazy good trap times. Your earlier R and T post had the car doing 119 but faster zero to 60 by a tenth and faster to 100 by the same margin.
C and D in the E63 vs M5 vs S6 comparo test had the M157 engine trapping 124 mph- WTF!!!!!
Old Jun 14, 2012 | 01:44 PM
BenzoBoi's Avatar
Super Moderator
W221
Nice find and thanks for posting. Love the 216 CL.
Old Jun 14, 2012 | 03:33 PM
TMC M5's Avatar
R&T doesn't weather correct their acceleration data:
http://www.roadandtrack.com/special-report/how-we-test
R&T usually posts in their data panels the ambient weather and elevation of the test track. If I recall correctly, they usually do most of their testing in Irvine, CA which is already at 1,000+' of elevation.
Alternatively, Car & Driver weather corrects its acceleration to "dry air" 14.7psi and 60 degrees.
http://www.caranddriver.com/features...braking-page-2
I would theorize that 9 times out of 10, the Car & Driver figures are going to be better because R&T is more likely testing in 1K+' of positive DA conditions whereas C&D's figures are likely producing sea-level acceleration figures. Even if R&T is able to test on a cool and crisp day, it will likely have a harder time gaining traction in those conditions.
Also, I am not 100% sure how they weather correct data but if it is anything like dyno SAE/STD correction, it could skew trap speeds. Sometimes you will see the SAE or even STD correction factors listed on the dyno charts. For example if the correction factor is 1.02, it would mean that the uncorrected whp figure was increased up by 2% to correct up to the SAE figure. A .98 correction means the opposite, the run was run in cold conditions and a 2% reduction was applied to the uncorrected whp. If this same methodology is used, the acceleration times won't be as impacted.
For example, say the acceleration times were recorded in relatively warm conditions that resulted in a 2% weather correction. The reduction in a raw 0-60mph time of 4.0s would only result in .08s being deducted taking it to a rounded 3.9s time. Meanwhile the 1/4 mile trap speed would be increased 2% to reflect that same weather correction. That could turn a raw trap speed of 120.0 mph into a weather corrected trap speed of 122.4 mph.
At least those are my theories on the disparities....
Tom
Old Jun 19, 2012 | 02:03 PM
tbal's Avatar
Haters crazy
We should note that for really serious torque junkies, with really deep pockets, there’s yet another CL in the lineup that may have even more appeal. The CL65 AMG is propelled by a 6.0-liter SOHC 36-valve twin-turbo V-12 developing 621 hp and 738 lb-ft of torque. If that’s not enough, you probably need therapy.
Lol
Old Jul 25, 2012 | 10:31 PM
fixinbones's Avatar
2016 AMG GTS, 2015 GLA45 AMG
Just made a deal on a 2011 CL63 with PP to replace my '09 CL63. My 09 doesn't have a LSD. Can anyone tell me if the 2011 and up CL 63s have LSDs? I can't imagine the car being able to rip off 0-60 in 4.0 and a 12.3 1/4 mile at 120 with an open rear end. Any info on this topic appreciated.
