CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL55 no sound out of drivers door & seats not massaging
Old Oct 29, 2012 | 05:03 AM
ryan_austin's Avatar
Cl55
Hi
Can any one help i just got this Cl55 2002 and driving it back home i found the drivers speakers seam to to be dead ( Spent all my time looking at ABC pumps and what not's not dam speakers ) i'm going to pop the door card off to night have a look and tip's on this also the seats are not massaging just here a light click seam's move ok all be it slow any help would be good .
Ryan
Old Oct 29, 2012 | 11:05 AM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Your speaker doesn't work probably because the harness that runs through the door has severed the wire. This eventually happens to all CL's. You will need to replace the door harness.
The massaging seats issue is a seperate item and could be the actual switch at the base of the seat or the actual mechanism in the seat.
R.K.
Old Oct 29, 2012 | 11:10 AM
Cl55
Ok thanks :-)
Old Oct 29, 2012 | 12:08 PM
Cl55
Can i just get the speaker cabal or need the whole loom ?
Old Oct 29, 2012 | 12:15 PM
awiner's Avatar
2003 CL55 AMG
You can simply re-soldier or z-splice the any severed wires back together. Sometimes it's good to add a little wire to extend the length as well however once fixed your usually good for another several years of use.
Old Oct 31, 2012 | 07:47 AM
Cl55
Done work a well that's guys :-)
