CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Intercooler fluid stand-alone circuit or shared with radiator coolant?
Old Nov 11, 2012 | 03:29 AM
nidyanazo's Avatar
550HP+ ///AMG CL55 Kompressor, Ducati 916bp, Yamaha R1 WSBK replica
Question Intercooler fluid stand-alone circuit or shared with radiator coolant?
Quick Q, is the intercooler pump and fluid shared with the radiator's coolant? Or does it have it's own stand alone tank/fluid that's not circulating with the radiators fluid.
Damn I really need that workshop manual .
Old Nov 11, 2012 | 02:56 PM
awiner's Avatar
2003 CL55 AMG
It is shared.
Old Nov 11, 2012 | 05:10 PM
alx's Avatar
alx
Correct. They share the overflow reservoir. No need to bleed either when redoing the ic pump.
The sl- class amg cars on the other hand have a completely separate coolant circuit.
Old Nov 11, 2012 | 06:31 PM
nidyanazo's Avatar
Great, that's what I was getting at.
I ordered the uprated 010 bosch pump, and wanted to make sure I do it right, bleeding the system and whatnot.. I'll most likely just flush the cooling system and refill with fresh fluid since I'm giving the car a tuneup.
Looks like it's as simple as locating the IC pump, removing and replacing it with the new one then. Thanks!
