CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Windows on CL55
Old Dec 19, 2012 | 03:05 PM
Benzin's Avatar
2005 benz cl55
Windows on CL55
Im having issues rolling my windows up with one click, it will only go half way and roll down a bit and stop. Now I have to hold on the button to have them roll all the way up. Before it would just roll all the way up with a click on the button. How can I get this resolved?
Old Dec 19, 2012 | 03:43 PM
awiner's Avatar
2003 CL55 AMG
Did you try to resync your windows by holding the button all the up to where the window is fully closed, then continue holding for 5 seconds?
Old Dec 19, 2012 | 04:05 PM
Benzin's Avatar
2005 benz cl55
yes, Ive done that but after couple days the same issue comes up
Old Dec 19, 2012 | 04:35 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Sounds like the wiring harness in your door needs to be replaced. The windows are losing their memory which means power is being interupted. Its a common problem on the CL's. The door harness costs around $220.
R.K.
Old Dec 19, 2012 | 05:00 PM
awiner's Avatar
2003 CL55 AMG
I have also seen window control modules go bad as well as other associated electronics that can cause these issues (such as the SAM's).
Old Dec 19, 2012 | 05:30 PM
PelicanParts.com's Avatar
SPONSOR
It may be the door harness but it could be something else less serious as well. E-mail Roy@PelicanParts.com for free tech support before you spend the money on the part. Once the issue is identified you can order the part on-line at PelicanParts.com or give us a ring and we'll get it shipped out right away.
-Trinidad
