CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Need some Part-Numbers for 03 CL55 AMG Kompressor
Old Jan 27, 2013 | 06:45 PM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Hi Folks,
i need Part Numbers for the following items for my 03 CL 55 AMG Kompressor.
- Front and rear Flex Disc
- Front Brake Discs and Pads
- Air Filters
- MAP Sensor,
- O2 Sensors (primary ones, not the secondary control ones)
- Spark Plugs (also the recommend ones by Forums, IIRC NGK???)
- Spark Plug wires (from ignition-coils to every second plug)
- The little illuminated knob that opens the glove box
- SC Belt (or some forum recommend alternatives, such as the infamous green belt).
- Aux Belt.
Thanks alot. :-)
Old Jan 28, 2013 | 07:20 AM
cm60k's Avatar
1) Flex Discs #: "215 410 00 15"
2) Front Brakes:
*Discs #: "220 421 19 12"
*Pads #: "003 420 71 20"
*Wear Indicators #: "220 540 07 17"
3) Air Filters #: "113 094 00 04"
4) Pressure MAP Sensor #: "005 153 72 28"
5) O2 Sensors #: "001 540 51 17"
6) Spark Plugs #: "004 159 13 03"
7) Spark Plug wires:
*"112 150 01 18" (9 wires)
*"112 150 02 18" (4 wires)
*"112 150 03 18" (2 wires)
*"112 150 04 18" (1 wire)
8) illuminated knob #: "220 689 01 01", you have to check that #, cause MB replaced it "3" times....
9) SC Belt #: "113 997 01 92"
10) AUX Belt #: "113 997 00 92"
ZAYED,,
Old Jan 28, 2013 | 07:39 PM
grane's Avatar
GLK350, SL63 AMG
Get your VIN
And enter it at Sponsor
www.mymercedesparts.com
and search for current parts. (The OP above was a good friend doing research but telling you to check for updates!) Jeff heads a parts dept. at a MB dealer and will check on the latest parts for you.
Jeff does a great job and tell him I sent you.
BTW I have a set of OEM spark plugs in MB sealed boxes I bought recently but don't need at a favorable price to you. PM me if interested.
Old Jan 29, 2013 | 05:43 AM
cm60k's Avatar
I didn't say "CHECK for UPDATED", i only mentioned about "1" #, to confirm it with MB dealer,
Cause sometimes MB replaces the interior parts to the new #s related to contracting with interior companies(which produces parts for MB)
in generally....
ZAYED,,
