weird vibration at 2000 rpm-solved
new tires made no difference.... but changed tranny fluid solved it! Make sure they drain the torque converter fluid also! Do not flush it
Adding my experience to this vibration dilemma. Initially I suspected torque converter but I started picking cost effective bushings and links to sort the vibrations out. Vibrations stared at 60mph+ but then developed a drivetrain shudder at 35-41mph at 1800-2000 rpm
flex discs done, carrier mount/bearing done, trans and engine mounts done... next is front control arm bushings(lots of play there) contributing to 50mph+ vibration and rear shock mounts I believe is responsible for slight intermittent shudders... Mercedes vibrations are annoying but I got rid of 95% of it. Will report back along with new tires and see what the culprit finally was.
2008 CL63
2008 CL63
