LH Front side marker message
I got and error saying l frt side maker bulb out
Changed Bulbs on both sides with std 194 bulbs
I usually have Auto selected on light switch
Start car and still have message for lh front side marker lt out
Here is the weird part..found out that-
Switch in AUTO-Turn key on marker works,start car and marker goes out on left front only(all others lights OK) and message on display
Put light switch in O position every thing is ok and no message
The only change I made prior was to install error free led city light bulbs which work perfect and no message
Is it possible to have feed back to the LH front marker only ???
So i did a test...
Remover led city bulb and put in new 194 bulbs
problem gone
i noticed-on key on bulbs power up and on eng start they go out briefly when cranking(I assume to make sure all power goes to stating)
The wattage or resistor must be off enough that the last bulb on line,
which happens to be the LH Front, would not restart on power up when engine starts
I guess my ERROR FREE BULBS ARE NOT SO ERROR FREE
What are people using in their city lights to make them whiter
