CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
where is cigarette lighter fuse on W215?
Old Jul 5, 2013 | 12:20 PM
SLCL's Avatar
CL55, SL500, E350
It must be a scientist to figure out where the cig lighter fuse is! I see in the chart as F86 on "Dash board right" but I've spent an hour taking the car apart and couldn't find it!
Is it under the glove box (which I opened and couldn't find)? Please help. I need to pump my tire with the portable air pump.
Thanks in advance for your help. It's a 2005 CL55.
Old Jul 5, 2013 | 01:52 PM
xabo's Avatar
'20 S63
Did you check the panel on the side of the dashboard?
Old Jul 5, 2013 | 01:58 PM
SLCL's Avatar
CL55, SL500, E350
Thanks for the reply. Where is that exactly? Is it the area where you can access when you open the door? I am not sure how to open the cover (or if it is in fact openable).
It driving me crazy and it 90+ degrees
Old Jul 5, 2013 | 03:24 PM
xabo's Avatar
'20 S63
http://www.mbusa.com/vcm/MB/DigitalA..._cl5565amg.pdf
Old Jul 5, 2013 | 08:15 PM
SLCL's Avatar
CL55, SL500, E350
Wow thanks for the link. I found it (page 397 in case someone else might look for it) and relaced it. They should have at least label "fuses" on the cover!
Something must have gone wrong. I've been using the pump for years without problem. I blew a fuse this morning. After replaced it (thanks gain), it blew again. I haven't done anything different.
Old Mar 4, 2021 | 07:25 AM
Marlo Tv's Avatar
2005 cl55 amg
Cl55
Do anyone knows where the location of the fuse for the cigarette lighter at
Old Mar 5, 2021 | 08:29 AM
CL500KRUZZ's Avatar
02 w215 cl 500
Lighter fuse
I was in the center of the trunk you got a pull the rug out everything and took me two years to figure that out
