CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
55k x pipe..vendor? Tuners?
Old Jul 21, 2013 | 11:52 PM
Blkvip's Avatar
12' E559
Trying to gauge prices on a x pipe. Essentially one that just "bolts up".Trying to keep the work simple for my tech so not really wanting to do custom route. I know modern horsepower sells them at about $530. Waiting on email from another place that makes 55k headers. Any other places?
Old Jul 22, 2013 | 06:42 AM
CharlestonN's Avatar
03' CL55 AMG
If you're not dead set on an X-Pipe i would recommend straight pipes, it will sound better and improve performance a bit since it's a supercharged engine
If it were NA or Turbo Charged the X pipe would be a better choice
Old Jul 22, 2013 | 08:20 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
If you go straight, then at least add a crossover pipe to equalize pressures. I still run an X pipe and it has a unique sound.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jul 24, 2013 | 10:46 PM
Blkvip's Avatar
12' E559
i find the sound of the x pipe "cleaner" than just straights. but this is not a question what i should get x or straight. Its who to get the x pipe from....
Old Aug 4, 2013 | 08:17 PM
Blkvip's Avatar
12' E559
no other inputs?
Old Aug 4, 2013 | 11:03 PM
03' CL55 AMG
Your best bet might be a custom fabrication, i don't see it costing too much more than a high end prefab
Originally Posted by Blkvip
no other inputs?
