CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
I have a major problem with my ABS and brake lights.
Old Sep 17, 2013 | 05:36 PM
W215mbzcl's Avatar
2003 MBZ CL55 2006 BMW 650
Well I'm not sure where to start. My rear brake lights wont turn off and I've already changed the sensor and everything that was suggested, but no luck. On top of that, my ABS and ESP lights are on. I also have another problem, my car sometimes has difficulty starting. For example, ill put the key in, turn it, and it starts fine. However, when I turn the car back off and try to turn the key again, it wont turn on. I have to take the key out, wait for about a minute, and the put the key back in for the car to start up again. So All in all, my three main problems are the car not starting, my brake lights not turning off, my ABS, and ESP. I changed the brake light sensor. What else is there?
Old Sep 17, 2013 | 06:07 PM
biker349's Avatar
cl600
have it diagnosed with a star computer.
Old Sep 17, 2013 | 06:09 PM
W215mbzcl's Avatar
I did, it told me that there's no communication with the esp, ignition switch, and it also gave me a brake switch problem - which I replaced.
Old Sep 18, 2013 | 07:33 AM
alx's Avatar
alx
Have your battery tested. Check fuses. It could be many other things too.
It is possible that your esp/ abs module is dead among others things
