CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
03 CL55 AMG - Camshaft Position Sensor
Old Dec 4, 2013 | 07:26 PM
larevalo71's Avatar
2003 CL55 AMG
Hello All. I need to replace this sensor. Can someone please post a picture of exactly where its at please! Easy fix Yeah Yeah Yeah !!!
I still need it !! Thank You..
Old Dec 5, 2013 | 02:11 PM
awiner's Avatar
2003 CL55 AMG
Part #17
Takes all of 5 minutes, 95% of that the time is removing the belt and pulley to access the sensor for removal/replacement.
Old Dec 5, 2013 | 04:21 PM
larevalo71's Avatar
2003 CL55 AMG
Thank You awiner. Any chance you know the bolt head size also??
I have 3 coolant hoses in the way !!! Plus a dual pulley setup right in front !!
Old Dec 5, 2013 | 05:02 PM
awiner's Avatar
2003 CL55 AMG
I don't remember off hand. It may be an 8mm bolt.
Old Dec 6, 2013 | 04:57 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I have plenty of gently used cam sensors here and some crank position sensors as well. PM me , if you want a used one.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
