CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
2003 CL55 Transmission and Supercharger Problem
Old Jan 28, 2014 | 04:57 PM
CL500to55's Avatar
2003 CL55 , 2004 911 C2, 1968 S280
Hey guys I've been having a problem with the transmission and supercharger.
A few months back i was driving the car ( in the middle east) and it got stuck in 3rd gear. I turned it off and on and it worked. It happened the next day and it got stuck in second but this time it wouldn't reset and CEL came on . So I took it to the mechanic and said the temp sensors got hot and put the car in limp mode. He said that the climate was too hot for it and the fan was still set for Canadian temps so he fixed it and it drove the whole summer.
I went back in the winter(cold weather) drove it and it did they same thing, It wont shift, supercharger doesn't engage and it jerks between r and d
any suggestions.
Old Jan 28, 2014 | 05:30 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
seems like a bad conductor plate. you will need to pull the fault codes from the transmission to confirm the problem.
Old Jan 29, 2014 | 08:35 AM
AndreNY's Avatar
couple of Benzos
Best thing is to pull the codes first before doing anything
Old Jan 29, 2014 | 09:12 AM
CL500to55's Avatar
What I remember from the scan it had P2200 and a bunch of other codes from a battery switch
Old Jan 29, 2014 | 02:00 PM
AndreNY's Avatar
couple of Benzos
get the car Scanned from a Mercedes Scanner not a generic one and tell us what it says
