CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL55 primary catalytic delete
Old Apr 3, 2014 | 11:53 AM
Afr00t's Avatar
'03 CL55 AMG & '09 SL63 AMG
Hello fellas. I need help figuring out the cause and effect of deleting my primary catalytic converters. I already have my secondary catalytics and resonator deleted. My main catalytic converter has gone bad and it's too expensive to replace it with OEM Catalytics so I'm thinking about deleting them completely. Will the car be too loud with prim cats/second cats/resonator deleted? will the check engine light come on or will the car performance hinder?
Old Apr 3, 2014 | 04:42 PM
Blkvip's Avatar
12' E559
you will in deff get a CEL. you have o2 sensors after the down stream cats. and another at the up stream. If you live in a state where emissions doesn't count for passing then you're fine. and you will be significantly louder in the higher rpm range lol. i have secondary cat/res delete, stock mufflers and its nothing crazy low end of the rpm range.
Old Apr 5, 2014 | 03:58 PM
Afr00t's Avatar
Emission isnt a worry in my state But will the engine starting running leaner/richer (possibly of a fault o2 sensor reading) and causes the engine to shake?
