CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
How to pressurize abc system in emergency ?
Old May 12, 2014 | 08:18 AM
tusabes's Avatar
Mercedes
I read in the valve block thread that its possible to pressurize the abc system manually- by using an air compressor in the abc fluid reservoir , to get the car back up- can someone please explain exactly how to do this ?
I have a CL with bad abc pump and its too low to drive or tow to shop or even get a jack under it . If anyone can explain how to manually pressurize the abc system using an air compressor in the abc fluid reservoir, and if that will get all 4 corners up, even temporarily , please advise !!
Old May 12, 2014 | 12:28 PM
awiner's Avatar
2003 CL55 AMG
Pressurizing the system is to get the pump to prime when dry. It will not help a bad pump raise the car.
Old May 12, 2014 | 05:16 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
The dealer has fixed blocks you can put in the wheel wells to hold the car level. I have used wood blocks in the past. You may have to jack the car up from the OEM jack ports, until you can get a big jack under the car.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old May 12, 2014 | 05:24 PM
Grip Grip's Avatar
SLK55 AMG - Renntech Supercharged
That's good info right there.
