CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL55 Coolant service
Old May 19, 2014 | 10:55 PM
mbenzCL55's Avatar
2001 CL55 AMG
I plan on renewing the coolant on my 01 cl55, I am aware of the drainage plug under the radiator to release all the fluid. What type of fluid would I need and do I have to mix fluid with water? I have a local German auto parts store I can pick the fluid up from. The coolant also seems a bit low, it doesn't fill to the top of the cap. Could I fill it up instead of flushing or would it be better to renew the fluid? Also is it as simple as an oil change or is there a special procedure to follow?
Old May 20, 2014 | 03:59 PM
mbenzCL55's Avatar
2001 CL55 AMG
I'm inexperienced with coolant servicing, any advice would be appreciated.
Old May 22, 2014 | 08:59 AM
mbenzCL55's Avatar
2001 CL55 AMG
Help please
Old May 24, 2014 | 10:20 AM
mbenzCL55's Avatar
2001 CL55 AMG
Bump
Old May 24, 2014 | 07:26 PM
biker349's Avatar
cl600
check the owners manual for type of antifreeze and change interval which i believe is 5 years.
Old May 26, 2014 | 02:35 PM
awiner's Avatar
2003 CL55 AMG
Coolant replacement is recommended every 15 years or 150,000 miles.
Factory MB coolant is cheap. That is what i use.
There are a couple alternatives such as Zerex G-05 but will not have the lifespan of the factory MB coolant.
Old May 27, 2014 | 11:04 PM
mbenzCL55's Avatar
2001 CL55 AMG
Where can I purchase the correct mb fluid? And is there any mixing of water required?
