CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Bad mattalic rattle cl55 need help diagnosing
Old Jun 8, 2014 | 08:15 PM
kneedeep's Avatar
2004 cl55
Ok so I thought it was the supercharger tensioner and replaced that but no luck.
Today I took off the supercharger belt and ran the car and there was no mattalic noise. I can move the idler pulley and it does have play but when I run the engine it really sounds like it's coming from the supercharger itself. Any ideas on how to narrow it down for sure so I don't throw more parts at it?
Old Jun 22, 2014 | 07:54 PM
kneedeep's Avatar
2004 cl55
Update - today I replaced the supercharger pulley bearing. Was a pia to do but doable for all us no nothings. Unfortunately it made no impacted on my bad rattle noise. It is definitely coming from the top front area of the supercharger. Now I'm leaning toward it being the supercharger clutch but I don't trust any of my guesses anymore. I REALLY would appreciate any help narrowing down the issue.
Old Jun 22, 2014 | 11:50 PM
awiner's Avatar
2003 CL55 AMG
Look at the other tensioner and see if the sound is coming from there. Drivers side of engine.
Old Jun 23, 2014 | 02:57 PM
kneedeep's Avatar
2004 cl55
Thanks. I did check the other pulleys and they seem fine. When the car is running the noise is definitely coming from the front of the s/c. Here is what it looks like now when I spin by hand. This is with the brand new bearing.
http://youtu.be/W9MFVWkqFXs
Old Jun 23, 2014 | 04:01 PM
awiner's Avatar
2003 CL55 AMG
May not be related, but have you changed the oil in the supercharger? (I know, this is not on Mercedes service list), but it easy to do.
When I did mine at 100,000 miles, a lot less came out than went in.
Old Jun 23, 2014 | 05:53 PM
kneedeep's Avatar
2004 cl55
Thanks for the suggestion, I haven't changed the oil in the S/C. Can't imagine it could fix my issue but it won't hurt I'll search for a how to and maybe give it a shot.
Old Sep 26, 2015 | 12:11 AM
khutchinson22's Avatar
CL55
Did you end up changing the supercharger oil? How did it turn out? Did this resolve your issue??
