CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Steps for replacing ESP module on CL 600
Old Oct 18, 2014 | 05:47 PM
CL600CK60V12's Avatar
2008 S65 AMG, 2005 SL65 AMG, 2005 Porsche Carrera, 2011 Shelby GT500, 2001 Acura CL Type S
I was wondering if anyone has posted or can post instructions (steps) for replacing the ESP module for 2003 CL 600. I had the car diagnosed and ESP is throwing an error "cannot execute torque request". Car runs but ESP acts up from time to time and I ordered another one and would like to replace it myself - it looks like plug & play module so it is worth a try.
Thank you,
S.
Old Oct 19, 2014 | 12:08 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
The module is located in the fuse box on the driver's side towards the windshield. There are locks on each side of the box you slide towards you and it unlocks the cover. The ESP module is the one on the inside (the outer one is the ABC module).
Old Oct 21, 2014 | 03:33 PM
ESP
thank you. It turns out, there was some corrosion on the connector of the ESP module. When I look closer at that fuse box, it is not much of a protection for such a critical component such as ESP (it is open on one side, towards the windshield and in that corner one can find a "nest" of leaves blown in).
Also, your "ABC Delete" thread is awe-inspiring .
Old Oct 22, 2014 | 11:50 PM
OCKlasse's Avatar
MBworld Guru
Thank you sir
