CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
level sensor in abc reservoir?
Old Feb 2, 2015 | 07:27 PM
biker349's Avatar
cl600
has anyone thought of how to, or installed a level sensor in the abc reservoir. it seems mercedes should of done this so the pump doesn't run dry and die.
what do you think?
Old Feb 3, 2015 | 01:00 AM
benz_addict's Avatar
V12TT
Pump has a restrictor valve when there's no fluid in the tank
Old Feb 3, 2015 | 06:45 PM
biker349's Avatar
cl600
thanks for the answer, but how does the restrictor valve stop the pump from running dry? i assume if we get a leak in a hose, or strutt and leak fluid and are not aware of it the pump will eventually run dry causing the abc pump to implode. wouldn't a level sensor warn us that the system is low on fluid thus allowing us to know that there is a problem before the pump runs dry? maybe i'm not understanding what a restrictor valve does.
Old Feb 3, 2015 | 08:14 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
You could buy the oil pan level sensor, find a way to seal it into your abc tank and wire it in to your liking.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
