German aftermarket 2 micron ABC filter, good idea?
Does this sound like good advice? Thoughts on other preventive maintenance recommendations would be appreciated.
The current MB ABC filter is 3 micron already. The stock ones were 10micron IIRC and therefor crap.
Otherwise you are only changing a fraction of the fluid. There is a WIS or Star procedure for performing this strut renewal as part of the entire "drain and renew" process- don't let someone tell you it doesn't exist. You can check this by looking in your OM that the capacity of the ABC system is much greater that the amount of fluid usually changed.
This ABC procedure is analogous to the 722.6 transmission fluid change that is on the dealer service adviser sheet. Now it is at 37kMiles. It calls for new filter, new gasket, clean magnet and 4 quarts of MB or Shell 134 ATF ONLY. However that transmission (in my CL55 -YMMV) takes about 9.1 quarts of fluid. What about the dirty and perhaps older spec 5.1 quarts that remain? Again, there is a WIS/Star procedure for draining ALL the fluid but you might have to elevate it to the service manager and find a tech with enough experience to believe you and perform it. "Drop the pan" fluid changes doesn't cut it with me.
Nest, I would recommend the above COMPLETE transmission fluid replacement at your car's mileage in addition to the COMPLETE ABC fluid drain and renew. You may have to find an indy who has a STAR/WIS computer that can plug into your OBDII system to perform the latter service. Basically there are drains on the struts that allow the car to "push out" the old fluid by gravity. Then the procedure becomes more complicated and you need a good tech with experience and the right tools and computer to complete the process without damage to the system.
Finally, I would have the rear end differential grease replaced.
Note: you can get both the Shell ATF fluid, transmission filters, etc. and the Pentosin needed for the ABC system at a great price on Amazon. It is the same stuff MB uses but in expensive bottles.
I am happy to receive corrections or further informed opinions on my descriptions and assertions.
What are your thoughts on changing accumulators at the same time. Cost vs benefit analysis? I have an indy shop with Star. Accumulators around $185 per plus 2 hours labor. I don't know if labor is per accumulator or I had discussed changing one with the flush.
