CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Window issue
Old May 18, 2015 | 09:09 AM
MrsCBR'sAMG's Avatar
2008 CL63 AMG
Window issue
I am new to these amazing cars and have one last thing to fix which has me stumped. The drivers side rear window is completely inoperable and I was hoping someone here has ran into this issue and could give me some pointers before I tackle it Wednesday night. I have found little in the way of diagrams of the fuse panels and even less about how to remove the interior to get to the windows drive motor. Thanks in advance.
Old May 18, 2015 | 07:14 PM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Probably the SAM?
Old Aug 2, 2015 | 11:55 AM
James Bradford's Avatar
2008 CL63
Have you heard anything else about this issue? I currently have the same thing happening. Same car as well.
Old Aug 2, 2015 | 02:16 PM
biker349's Avatar
cl600
could be the window motor, or switch as well. hopefully it's and easy cheap fix.
Old Aug 2, 2015 | 02:28 PM
awiner's Avatar
2003 CL55 AMG
Usually the motors go out. They use plastic gears and many times those break from age too.
It could be a other electrical issue (Switch, SAM, etc.), but 9 out of 10 times, its the motor regulator.
My drivers side rear was the first motor to go out as well.
Old Aug 2, 2015 | 06:38 PM
2008 CL63
The rear window isn't getting power from either switch. Do any of you have a part number for the window motor? A wiring diagram showing the relay to that motor?
