CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
lights flicker when headlights are on
Old Jun 4, 2015 | 01:45 AM
d00bies's Avatar
cl55
interior lights, radio, brake lights all flicker when the headlights are on. shows fog lamp error code but all the bulbs are fine. alternator is good. probably gonna check all the grounds. anyone ever have this problem?
Old Jun 13, 2015 | 06:11 PM
Mi55ile_AMG's Avatar
2003 Mercedes Benz CL55 AMG
I was having the same issues with my car but for my car the culprit was the alternator. The lights would flicker along with everything else. It probably is your grounds. Give them a check up!
Old Jun 14, 2015 | 05:45 AM
optimusprime m1's Avatar
W124 260E
Mi55 i go along with your post .1 Earth points 2 Alternator regulator change 3 Contacts on battery
Old Jun 16, 2015 | 05:56 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Good to change out the regualtor if you have over 60K or so.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jun 17, 2015 | 04:11 AM
W124 260E
Well i must be doing well ,my alternator as been on the car 26 years only thing i have done is that i purchased a set of carbon brushes and fitted them in to the regulator.,,But i have a new regulator spare in the garage.
