CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
RE CL63 MAJOR ENGINE ISSUE
Old Jan 15, 2016 | 03:01 PM
college66's Avatar
Mercedes CL63 AMG
Hi all,
Can someone give me their thoughts on the diagnosis below that I received today please. Someone has said that someone had the exact same symptoms on this forum and had the timing corrected and the car was fine. If this was you, I would love to hear from you and others opinion on this the issue below.
The car has only covered 81,000 miles and has full MB service history.
Fault codes for misfiring on cylinders 1,5,6,7,8 in fault memory as well as
0760 (Left intake camshaft Hall sensor):The time of the signal value change
is implausible
Cleared fault memory and after cranking the fault code 0760 had returned.
Carried out compression test on Star. ECU reporting RPM difference of 267
RPM, maximum permissible difference 28 RPM. Suspect internal engine
damage with fault code 0760 perhaps indicating camshaft timing is out.
