CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
2003 CL55 AMG Renntech Door Locks
Old 04-26-2016, 09:11 PM
api3517's Avatar
2003 CL 55 AMG Renntech
Hello, Im new to the Mercedes world but I could not pass up on buying this car/beast. The car has a few issues but I want to start with the door locks. My doors will not lock or open using the key or buttons inside. I have to manually lock the doors. Any ideas???
Al
Old 04-26-2016, 09:17 PM
Super Moderator
awiner's Avatar
2003 CL55 AMG
My initial guess would be your PSE (Pneumatic Support Electronics) pump that controls that circuit is bad or has a leak that shut the circuit down.
Pull the 20A fuse that controls the pump which will reset the circuits. Then try again.
Or have the system scanned and see what codes are being stored.
Old 04-26-2016, 09:30 PM
api3517's Avatar
Thanks for the reply,,, where is that fuse located? Where is that pump located? Thanks again!
Old 04-27-2016, 04:30 PM
Super Moderator
awiner's Avatar
2003 CL55 AMG
The fuse is located in the fuse block below the rear passenger seat leg area. You will see the cover. It is one of the yellow 20A fuses on the top row towards the middle. It is OK to pull both one at a time then replace after a few seconds.
The pump sits behind the carpeted paneling on the drivers side in the trunk.
Old 04-27-2016, 10:08 PM
api3517's Avatar
Thanks for the help, Ill check it tomorrow!!
Quick Reply: 2003 CL55 AMG Renntech Door Locks
