CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
My w215 CL55 ABC Delete Thread - Yellow Speed Racing Coilover Conversion and Review
Old 05-18-2016, 07:23 PM
aarkaah's Avatar
'12 E550 | Sold: '03 CL55 '06 E55 '00 E55, '97 BMW 540i, '85, '87, '91, '93 &'94 Mazda RX-7s
Originally Posted by renault12ts
Could you post those pics here and then verify which you used?
Great write up.
I honestly don't know what they sent me. But mine looked slanted. I sent them these pics.
Old 05-19-2016, 06:03 AM
renault12ts's Avatar
W215 CL500 2005
Thanks.
Old 05-19-2016, 06:14 AM
tusabes's Avatar
Mercedes
I've seen turbo 600s under $7000 without abc issues . You should be able to find cars with abc issues under $5000
Old 05-19-2016, 07:04 AM
W215 CL500 2005
Originally Posted by brianomerc
Hi all I removed my left hand front abc strut this morning my top mount is slanted yellowspeed told me most cl are flat so double check before ordering.
So, the original strut is slanted at the top...could you post a picture?
Old 05-19-2016, 10:37 AM
fireman685's Avatar
2005 CL55
When the bushings went out on my lower control arms of my CL 55, I replaced the control arms with W-2 20 Airmatic ones. Besides having the attachment for sway bars the airmatic control arms are significantly different. The strut on a CL is straight up-and-down. The attachment point for the strut on a 220 lower control arm is about an inch and one quarter closer to the wheel than the ABC LCA. So when letting the ABC strut hang naturally it did not line up with the attachment point on the lower control arm. I then had to forcefully pull the shock towards me to be able to attach it to the lower control arm. With the yellow speed coil overs, I don't imagine the flat mount would have the flexibility to allow you to pull it like I did with the ABC struts. Maybe the slanted mount alleviates that issue. Thoughts? Also I was under the impression that the camber on the rear of the CL's was not adjustable, only the toe. By the way thank you so much for a most excellent write up. I apologize for any misspelled words or grammatical errors but I'm dictating this from my phone. Ken.
Old 05-19-2016, 12:36 PM
W215 CL500 2005
I had the same thought about using the W220 arms and thus the slanted top...but awaiting something from Yellow Speed.
Old 05-19-2016, 01:13 PM
  #32
brianomerc's Avatar
Mercedes cl w215 55 amg
My top mounts were slanted you have to remove the strut to be 100 % sure.any luck with the abc warning light delete?
Old 05-19-2016, 03:16 PM
  #33
W215 CL500 2005
Post a pic of the top of one...please.
Old 05-19-2016, 04:26 PM
  #34
aarkaah's Avatar
@fireman685,
Thanks. I think I read a post from you regarding the pull of the front shocks to align with the w220 lower control arms. In fact I was going to go this route and I had already purchased a set on sale on AutohausAZ. However, I just had a second driving opinion from a friend with a W210 E55 AMG who also knew my car when it had ABC. He drives way harder than I do and he seems to think Sways aren't needed ... at least not yet. I will hold off for now.
I will pose the question to Yellow-Speed support to confirm - not sure if they will have an answer for this one though.
Thanks again.
Old 05-19-2016, 04:45 PM
  #35
aarkaah's Avatar
That's crazy... but I guess the body condition and miles need to be considered also. that's... way low...
Old 05-20-2016, 01:11 PM
  #36
AndreNY's Avatar
couple of Benzos
not really there is a CL65 with 80k miles with ABC issues for sale now for $16.5 and the car is really clean, these cars once they have suspension issues they are super cheap
PearlSchult08 (11-26-2017)
Old 05-20-2016, 02:30 PM
  #37
brianomerc's Avatar
Hi I have removed fuse 46 and 9 abc red warning light is gone only Wight warning on and you can just scroll past it.
618Syndicate (12-19-2019)
Old 05-21-2016, 08:33 AM
  #38
aarkaah's Avatar
They are a steal.
Old 05-21-2016, 08:34 AM
  #39
aarkaah's Avatar
@brianomerc,
Can you scroll with the car started up and running?
Does anyone know what the Strutmasters cancellation achieves?
Old 06-04-2016, 06:29 PM
  #40
brianomerc's Avatar
Has anyone removed abc warning lights without the strutmasters kit
Old 06-04-2016, 07:45 PM
  #41
aarkaah's Avatar
@brianomerc,
I don't know if anyone has. I keep asking on the forums and never quite get an answer. Here's what I do know about the options:
1. Strutmasters cancellation unit is available. Question is what does cancellation do - does the ABC warning go away completely (no lights, white or red)? If not, what remains after the cancellation module is installed? If it clears then this is the way to go. (can anyone tell us what happens with this option?)
2. Pull ABC fuses F9 and F46 - leaves you with the White ABC warning. However, you can scroll through the dash. Question is can you scroll messages with the key in ignition and car off AND/OR when the car is started? Or do you have to clear the white msg with the Reset Button? (can anyone tell us what happens with this option?)
3. Coded Out ABC - My dealer coded out my ABC (they may have just done option 4 for me). I went from the Red ABC message to the White ABC message. I can scroll with key in the ignition and car off. When the car is started I cannot scroll unless I clear the message with the Reset button.. ABC message is "Display Defective ABC visit workshop". (from me)
4. Pull the CanBus Connector on the ABC Module. There are only 3 connectors going to it. Its the middle one with only 2 wires going into it. Just pull it out. You'll get the display defective message but you can clear it using the dash reset button. (from Peter)
C'mon folks... chime in now... especially the strustmasters folks and anyone with a successful remove of the ABC msg.
Old 06-05-2016, 04:59 AM
  #42
brianomerc's Avatar
I have removed both fuses I did not try the reset button, my mb dealer will not even try to recode for me,as far as I know the strutmasters module removes all abc messages. I just fitted my coilovers yesterday I am happy so far car feels great a bit bouncy I'm still ajusting the damping settings I have only covered 20 miles.
Old 06-05-2016, 08:14 AM
  #43
aarkaah's Avatar
@brianomerc,
What are the specs on your wheels, current height and settings so far? Where are you located and road conditions? Any rubbing?
An alignment helps, but remember it will settle a tad. So hold off for at least 200 miles but drive it frequently.
I had my last adjustments on height Yesterday and will complete my second alignment tomorrow. I am now testing different settings on front and rear to get everything nice.
Let us know how you get on. And, send pics.
Old 06-05-2016, 08:32 AM
  #44
brianomerc's Avatar
19 inch amg wheels 245 40 19 front 255 40 rears soon to be 275 rears no rubbing .road conditions are old country roads with dips and bends so far I'm happy .height 27 front 28 rear will ajust after 200 miles .will post pics asap
Old 06-05-2016, 08:33 AM
  #45
brianomerc's Avatar
I'm in ireland
Old 06-05-2016, 10:04 AM
  #46
aarkaah's Avatar
What's your setting? Clicks from softest? With 19s you could easily go to my height without rubbing. That plus alignments will help the bounce go away.
I myself remain at 30 clicks from softest.
Old 06-05-2016, 11:28 AM
  #47
brianomerc's Avatar
I'm running with 25 clicks from softest at the moment. I also bypassed the abc pump no issues car sounds a lot better my abc pump was very noisy but was working perfectly.
Old 06-05-2016, 12:47 PM
  #48
brianomerc's Avatar
Old 06-05-2016, 12:48 PM
  #49
brianomerc's Avatar
Sportunage (04-22-2020)
Old 06-05-2016, 12:51 PM
  #50
brianomerc's Avatar
Quick Reply: My w215 CL55 ABC Delete Thread - Yellow Speed Racing Coilover Conversion and Review
