CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
How to change parking lights?
Old Jun 15, 2016 | 04:25 PM
chmercer's Avatar
2006 e55, 2008 cl550
Had a bulb go out in the bottom of the right headlight, owners manual doesn't outline how to access this bulb. Can anyone point me in the right direction? Thanks!
Old Jun 17, 2016 | 01:03 AM
fireman685's Avatar
2005 CL55
Are you talking about the side marker light that's in the bumper? If so there's a little access panel under the bumper on each corner for you to reach your arm up in there to switch out the bulb. Took me less than 2 minutes to change it.
Old Jun 20, 2016 | 08:22 AM
chmercer's Avatar
I am talking about the one that is integrated into the turn signal, like a bottom eyelash? I can see the bulb slightly if I pop off the larger of the 2 headlight access panels but can't seem to get to it and it feels like I am trying to make it more difficult than it is supposed to be haha
Old Jun 20, 2016 | 09:06 AM
chmercer's Avatar
Figured it out, for anyone else confused in the future, these are accessible from the front fender wells, not the engine bay.
You have to remove 3 push rivets and pull the front of the fender liner back. Then there is a small cap that takes a quarter turn to remove, then the bulb socket is in there. You pull it straight out, it doesn't turn.
Old Jun 20, 2016 | 07:03 PM
biker349's Avatar
cl600
thanks for the info.
