CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Cruise Control Inoperative
Old Aug 14, 2016 | 12:43 AM
khutchinson22's Avatar
CL55
When I flip the switch to engage the cruise control it seems to begin but immediately stops, the cruise indicator dashes flash and then return to their normal state.
This just started happening. I just recently replaced my tires but they're the same size. I have been getting a random, inconsistent, left rear turn signal error as well as a brake light error. I don't know if they're related but I figured I would mention them. There are no dash warning lights and no other malfunctions at this time.
Any ideas, fellas?
Old Aug 14, 2016 | 07:56 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
I don't know if this relates from other models, but I'd check the brake light switch on the pedal.
Old Aug 14, 2016 | 06:39 PM
CL55
New information:
I just discovered that the cruise control function at lower speeds so it appears that the problem only occurs at higher speed leading me to believe that it wouldn't have anything to do with the brake switch.
Old Aug 17, 2016 | 07:49 AM
TwinTurboTim's Avatar
2006 CL65
All the bulbs good in the rear.
Old Aug 17, 2016 | 09:33 AM
CL55
I've been getting bulb errors but all bulbs look good.
Old Aug 19, 2016 | 08:47 PM
2006 CL65
I honestly think the bulbs need to be working for the system to work. It was like that in the early year cars but I am not sure if its that way in the newer cars. The system uses existing hardware like the drive by wire so there isnt much that will go wrong for the cruise other then the switch.
